Not so awesome spaghetti
printing a marching baritone model and most of the print printed fine. The valves in specific are spaghetting.
I need help
We can try to help but more info would be nice.
You put a dead print on a pink paper, then went to the world here. look. look at my dead print on a pink paper.
No machine info, settings, plate, display, image of it failing on the machine, video, noise, fax, birdcall, bottled message - nothing to give us a clue.
Just here, spag on pink. 0/10
:+1:
Sorry. I posted this in a hurry and I just used default settings. It was an A1 on the textured plate. I’ll try to reprint it when I get back home.
I’d also appreciate it if you were a bit less passive aggressive, but I understand your frustration and I am sorry.
I don’t think it pinged you. @Unique_Letterhead
The problem was just the SD corrupted some of it. I sent it in from the slicer and it worked fine.
Glad you got it sorted and sort of an unexpected solution - but there end up being a fair number of reports of bad SD cards here too.
If you got a corrupted model on yours, you might want to replace it. It could be early warning it’s dying. Some SD faults do odd things.
