I used to experience nozzle dragging across build plates on bedslinger type machines — and even more alarming stuff like the printer head entering a violent jackhammer loop pounding the nozzle into the build plate with huge force.
This never seems to happen with core XY machines for me at least.
I entered your situation into Google AI and it returned excellent insights:
“Removing the build plate entirely while the machine is on or moving is the exact trigger for this specific disaster.
What happened to your friend is a direct consequence of how the Bambu Lab A1 tracks its physical position, combined with a crucial user error during the termination sequence.
What Triggered the Crash?
When a print job is terminated, the printer doesn’t just instantly freeze in place forever. The machine executes a mandatory “End G-Code” sequence. This script tells the toolhead to clean the nozzle, move the Z-axis, and return to its physical home position to safely park.
By ripping the magnetic build plate off the machine while the printer was actively trying to execute this automated parking sequence, the user broke the printer’s safety loops in two ways:
- Lost Z-Height Calibration: The Bambu Lab A1 measures its Z-offset by physically tapping the nozzle onto the build plate. Without the plate, the metal surface sits roughly 1mm to 2mm lower than the digital brain expects.
- Missing Sensor Baseline: When the toolhead moved to its home corner to park, it descended to search for the bed. Because the plate wasn’t there, the nozzle plunged past the digital “zero” line. The strain sensor failed to register a tap at the correct height, and the stepper motor kept driving the nozzle downward, dragging it sideways right across the bare magnetic heat bed sticker. [1]
Damage Assessment & Next Steps
Your friend needs to check for two types of damage immediately:
1. The Magnetic Heat Bed Sticker
- Cosmetic vs. Structural: If the nozzle only left a silver scratch or a minor indent on the black magnetic sheet, the bed is still perfectly usable. They can just put the steel PEI plate back on top and keep printing.
- Severe Gouges: If the nozzle physically tore, gouged, or plowed up a raised ridge of rubber/magnet material, the steel plate will no longer sit perfectly flat. A warped plate causes automatic bed leveling to fail. If the surface is uneven, they will need to purchase a replacement Bambu Lab A1 Heatbed Unit. [1]
2. The Toolhead Assembly (Hidden Damage)
A severe mechanical crash against the solid bed frame almost always bends components. Before printing again, they must check: [1]
- The Nozzle: The quick-swap nozzle tip is likely bent or blunted from the friction against the bed. Tell them to swap in their spare nozzle immediately.
- The Heater Screws: The massive force of the crash likely loosened the four small screws holding the internal heating block assembly. They must remove the front toolhead faceplate and tighten these screws, or the printer will continue to scrape future prints.
- Full Calibration: Once everything is tightened and a new nozzle is installed, they must run a Full System Calibration from the A1 touchscreen menu before starting a new print. [1, 2, 3]
The Golden Rule for the A1: Never touch, remove, or clean the build plate until the toolhead has completely stopped moving, the screen reads “0% / Ready,” and the cooling fans turn off.
Did the nozzle tear through the black magnetic sticker, or is it just a superficial scratch? Let me know if they need help figuring out how to check the internal toolhead screws for damage!”
You can cut and paste the discussion above into Google A.I. and continue conversing with it on your situation and concerns, and I am certain it will help you immensely! Be well!
