Nozzle Identity Issues?
Yup, exactly the same problem with E3D nozzles. If I press read nozzle info from the printer - it recognizes it 100% of the time, but time to time nozzle check before the print throws an error. I HOPE THAT BL ARE NOT LOCKING DOWN EVEN FURTHER.
See the following thread - there is a workaround (so far). It means aside from maybe shining a flashlight just so at the head when it looks at it with the camera, you can create a separate printer profile and edit out the section of g-code where it does the nozzle ID check when you send the sliced print job to the printer. Dunno how often it does the nozzle check, like for sure when you power cycle the printer, but at least this way I can send print after print to it and it won’t check the nozzle again unless it’s told to.
There is clearly a problem of detection during the print. For me, personally it happens every 3rd-4th print after the power cycle.
After that, I can power cycle the printer and then it detects it again for the next 3-4 prints. Also, at any point in time (while it’s idle) I can press “Read nozzle info” on the screen and it would read it correctly 100% of the time (I’ve tried about dozens of times).
So… it does feel like they broke something half-way. Can someone open an issue with them about this?
I did open an issue with them (BL). They are still “investigating”… lol…
Where did you open it? General support? Can you share your ticket number, I will submit mine and link with yours?
Apparently those dips**ts marked my ticket as Resolved - where it decidedly is NOT effing resolved. I had to use G-Code to get around their BS. Ticket #US260312140002
I really hate when support closes something that isn’t supposed to be closed :-/
Same issue here with the Obxidian 500 on my H2D. I received today 2 diamondback nozzle and now it sees them as High flow TPU nozzles…
I hope they resolve that quickly
I don’t expect Bambu to resolve the E3D nozzle issue. They are blaming E3D - this is from my Bambu ticket:
“we have received feedback from the relevant team. The issue is caused by E3D incorrectly using a color for the hotend identification flag.Please contact E3D customer support”
So it looks like Bambu changed the code and the rules and then blamed E3D. Pretty much thinking this vendor is not very above board at all. Not sure what E3D is gonna say, not like they’re gonna replace all my nozzles.
I did update the ticket explaining that E3D is a company AUTHORIZED by Bambu themselves, that the nozzle ID’s worked perfect before the firmware update, and to please escalate the ticket higher up in management as their response is a non-sequitur.
This is ■■■■■■■■, the diamondback are black and they are being scanned wonky everytime
It’s not because of the colors for sure, they need to push a fix as soon as possible, this is so annoying
Same issue here with the tungsten carbide nozzles 0.4 HF and normal.
So it appears that the $180 I spent on E3D Obxidian HF nozzles was a waste of money? My H2D just refuses to recognize them - alternatively says the are “unrecognized” or puts on of the two as a 0.6 or 0.8 instead of a 0.4. Every so often it works and recognizes one of them as the E3D, but very rarely. What a joke.
Best bet is to edit the g-code in the printer definition (make a custom one, call it “H2D Bambu Screwup”? lol), that bypasses the hotend identification code each time you go to print something.
Under the printer presets it’s “Machine gcode” → “Machine start G-code” and just comment out the following lines (this is from my config):
;M1002 gcode_claim_action : 72 ; Hotend Type Detection
;T1001
;M972 S14 P0 T5000 ; nozzle type detection
Then just set the heads to be High Flow hardened 0.4 nozzles on the LCD screen and it will work.
The times it get seriously annoying is if you try to do any automated calibrations of new filaments as it sends gcode you can’t see as part of the calibrations - you will have to keep resetting it.
Thankfully they weren’t able to jack with my H2S as it cannot visually inspect the hotend, so their attempt at restricting the use off off-brand hotends instead of buying their tungsten high-flows won’t work on that machine.
I’m working with the company I bought the hotends from to replace two of them since Bambu is blaming E3D instead of admitting they jacked up the nozzle ID step in their firmware, as it worked just fine on the earlier version.
Thanks! This is very helpful. Both E3D and the company I bought the nozzles from replied and both blamed a Bambu firmware update. E3D said a fix is being done. We shall see. I looked again at what I paid and it was $250 not $180. Expensive paperweight…. While both companies were responsive, what surprises me was that they are still selling them while knowing that they don’t work. I would have thought they would have pulled them from the market until the fix was done.
I have a round 700 hours on my H2D and I have never had this problem until this latest for more update which I installed last week. I use all factory Bambu nozzles, so I think this is a bug which will probably be fixed… eventually.
I have not done much testing yet… Next I will try pulling off that decorative cover… and I might try to figure out if there’s a way to do a firmware downgrade…
I have a new H2D, I have been printing daily on it, I run calibrations regularly, clean regularly and have not had any issues. I am trying to print large, rough objects like shelves and peg board, so I switched to 2 .6mm tungsten carbide nozzles (I print a lot of abrasives). From day one, between prints, the printer loses the hotends. They are brand new, from Bambu Labs, and everything is clean. I can set the hotends on the LCD screen, by the time I walk 6 feet to my computer, it is already gone from the system. I can refresh from the computer, by the time I get to the slicer, it lost it. I can sometimes get it to hold long enough to start the print and it will hold the information for the rest of it.
It has the latest firmware and this literally started only AFTER I changed to the .6mm nozzles. This was DIRECTLY related to the change, as this has NEVER happened before.I have had the printer for only about 4 months.
If anyone ever figures this out, or if Bambu ever hires non-Chinese nationals to help customers, please update everyone here.
Funny, I’ve only had my H2D for a little over a month. Has run flawlessly until I switched to 0.6mm Tungsten nozzles. And yeah, they are Bambu nozzles. Now occasionally losses it’s mind and can’t identify the hot ends.
My h2d has never given me any issues until this week, and now it will not recognize the nozzles every time. every time ihave to hit ignore nd continue. stupid thing. so annoying.
Yep, I have had the same problem with .6mm Tungsten nozzles. Something about the fiducial markings on that nozzle.
So I have Bambu .6mm Tungsten nozzles loaded. Ran a test where I tried to identify the nozzles 10 times. Failed 7 and was successful 3. Then I illuminated the nozzles with a flashlight when they pause in front of the camera for ID and they were successfully read 100%. Then I turned off all the ambient lights near the printer and it could not read the nozzles. The vision ID is having trouble with the fiducials on the .6 Tungsten nozzles. Never a problem with the .4mm
