Object too large for printbed. Can't split
do you mean cutting? Works for me on BS and Orca
Edit: ok you mean the other split, got it. That only works if you have 2 objects that were joint together. The Model you want to print is just a single piece. You’d need to use the “cut” function to split it up in 2 or more.
