Optimizing a Weave Pattern Print
Hello, I am new! I just bought a P1S recently and am trying to print a weave pattern.
I designed the weave pattern and I am running a couple experiments to try to optimize the print speed and quality but I am hitting a wall.
If you are more experienced with modeling and or slicer settings I would appreciate any help or advice.
I am primarily using PETG which I have dried for hours. The humidity is around 15-19% once I begin printing.
The main issues I’m facing are stringing and the quality of the print. There is stringing over many of the holes and it is giving it a look that is undesired.
I also feel like the slicer itself is slicing it in a weird pattern. Instead of going left to right or simply laying the under layers of the weave then the top layers it does odd patterns that fills some of the holes.
Is there a better way to design the pattern? Or a slicer setting to make it better?
Would you suggest a .2 mm nozzle, .4mm nozzle, .6mm nozzle, or .8mm nozzle?
I am currently using a .4mm nozzle.
I’ve attached the file. Let me know if you need any more information to help me. Again I am new and don’t know a ton, I’m trying my best!
Thank you so much
3Experiment_WavyWeave_CylinderBase.3mf (9.4 MB)
