Is there a print settings option to reduce the print speed by percentage for all settings across the board except for acceleration? Or is there just the button on the device page? Hoping for something that I can save in the print file for reuse. Thanks!
Select a preset you want to base this off of
Global Process → Speed tab
Calculator
Enter new values
Press save
Name your preset something useful, like $OrigName_Slow
Select this preset instead of the normal one you’d use
When you say calculator you just mean manually adjusting the speed values right? There isn’t a global speed % field?
Orca has a global parameter to scale speeds.
Studio does not, I would guess because Bambu has its own speed multiplier with the quiet/standard/sport/ludicrous thing.
I’ve been using OrcaSlicer for over two years but I’ve never found an individual setting that scales all speeds. Where are you finding this magic?
Sorry. Maybe I remember wrong. Cura?
Bummer - but using H2D so Orca isn’t useful anyways =(
