Outer "shell" missing after scaling
When I slice the model after scaling it down, the slice preview is showing the outer “shell” is missing. It showing as translucent …
I’ve scaled many prints in the past and never had an issue like this.
thx for your help!
Did you try Strength>Detect thin wall?
When you scale you scale everything including the thickness of the wing covering. I would imagine ‘arachne’ wall type is already selected if not I would also try that.
@Lenyo Thanks for the info!
You were correct. Detect thim wall was not selected. Turning it on solved the issue. arachne wall type was not on by default.
*i appreciate you mentioning that scaling down the model will also reduce the wall thicknesses too. i knew that but didnt think about it…
