Outer wall not sticking
Check units. That math is deriving the speed (mm/s - distance per second) and wants you to send the result into your process → speed → wall speeds (etc). That field in the filament profile is expecting the mm^3/s which is volume per second.
I would also kinda ignore the second part of that projects recommendations! Get your number for flow rate and thats good to go. In a modern slicer, under filament → volumetric flow rate, this rate acts as a speed limit. Your speed is automatically slowed down if the speed of printing would cause the extruder to exceed this flow rate. If curious, you can try it yourself in the slicer preview. Set your rate to a small number, reslice, and analyze the previews with dropdown → speed and dropdown → flow.
I changed a few other settings and re-printed test v3
…and whilst it IS better, it is still peeling away very easily…
At about 1cm from the ends (of the 100mm test piece) it is stuck good and proper and cannot be peeled off even under force, the middle section can still (even at increased flow rate of 1.00) be easily peeled off with a finger…it just aint stuck !
So apart from why isnt it sticking, the question is why isnt it sticking only in the middle…
I have just rotated the piece 90 degrees to see if it still does it then…
…and with it rotated the troublesome side (now printing front to back rather than side to side) printed and stuck perfectly and cannot be peeled even with a screwdriver and considerable force …hmmm
I’m curious now too and am printing your test3, albeit with PETG-regular [Vendor = Kingroon], not the HF stuff, so I’m expecting mine to look a little raw pushing it so fast
Open 3mf → slice → print, no changes to the setup
My changes introduced into this would be
  1. PETG-Regular being used - the vendor is Kingroon, and this isn’t an endorsement of them, their stuff is definitely low quality, its just what I had laying around lol
  2. This roll I normally print with flow 0.985 and no shrink factor, so the project is telling my machine to do ~2% more extrusion from the settings I would normally use - not a whole lot but worth mentioning
I got a little drooping on the bottom fillet and the wall looks a lil mottled from this material at this speed, but yknow, overall ok.
I took the knife to the sides of it and couldn’t get them to come off in sheets, or really come off at all.
Your directionality is interesting and I really don’t know what to recommend to tackle that. Older printers used to behave like that when their fan vent was only on one side of the nozzle, but the A1 does a decent job of encircling it.
thank you for doing that…I have wasted monumentous amounts of filament and would not expect anyone to do likewise!
I am now trying it with the outer wall acceleration set to 500 (instead of 5000)
I doubt whether it will help but we ARE now clutching at straws
what is your printer?.. mine is a A1 and was new in December…and it hasnt had much use - maybe 5 reels
  • edit*
  • nope, with that setting it’s still the same - i.e. barely stuck, all the layers behind it are fine
My test3 was done on my oldest A1 (001, Bulbasaur <3)
He’s got 3307 printer hours and lots of history lol
I’m doing a test now with the precise wall and underextrusion to see if I can even replicate the problem, cuz now I’m secondguessing my sanity too :slight_smile:
OK, thats kind of you, thank you
looking back over all the things I have printed - mainly box type items and of course the ubiquitous poo bin :slight_smile: it is apparent that this has been an issue since I got it…every item with a vertical part has the same problem on the same face…
In an effort to replicate your problem, I loaded your testv3, changed my filament flow to 0.85 and turned precise wall ON
I was able to get that “outer sheet” hanging off it, with a well-fused inner wall block. The first pic shows the position of the portion of the wall that was actually fused (about 1.5cm in)
I’m choosing to ignore the directionality since I really dont know what to say about that LOL but maybe try boosting your flow EVEN more! 1.05 go for broke? :smiley:
ah, I guess thats good…but its also bad !
surely increasing the flow is just masking the problem rather than curing it, and may well cause other issues…when I first got it the first few layers were rough as hell and also stringy, I am fairly certain calibrating the flow cured it
I am an engineer and thats how I’ve always worked…find the cause and cure it rather than cover it up :grin:
There HAS to be a cause for this and I will eventually find it…but eventually really needs to be now as I have projects to print
I dont think boosting flow past 100% is masking a problem, it’s addressing it. This is part of dialing in a filament. I agree that if this is bambu filament then the bambu profile should Just Work© but here we are in reality :wink:
Ex: If the diameter of your filament roll is 1.72mm diameter due to run of the mill inconsistencies, 102% would be the correct value to start with to fulfill what the slicer expects volumetrically. Those guys who recycle PET bottles into strips and stuff have to run their gear at 125+% cuz the filament it creates is only like 1.4mm.
Do you have a pic of the flow rate calculation prints you did on that filament? I like using: Set filament to 100% flow, load orcaslicer YOLO flow rate test, print. It’ll be a very good representation of flow rates of 95 → 105 which I would argue is the legitimate band of most quality filaments.
I selected 0.025 - the middle one
out of interest I tried printing with the Bambu studio slicer…and, not surprisingly the results were exactly the same !
I have this afternoon cleaned and lubricated the slides and guides etc. and also run through the belt tensioning procedure …none of which has made any difference
In answer to your previous comment I used the two pass flow rate test in Orca where it printed out 2 groups of tags
1st was 5, second was -6
I did a print at 1.05 and it does appear to have stuck…but… the edge is quite distorted and wavy
got this reply from Bambu…
Thank you for contacting Bambu Lab support. I am sorry to see that you are experiencing problems, but rest assured we will provide support to solve them as soon as possible.
I reviewed you files , but you just print too fast because your max volumetric rate is too big and for PETG you need value of about 7 to 10
I think a) 7 to 10 is too low and b) I did all the calibrations and printed all the calibration models and the volumetric came out at the value set (25)
I have since run the auto volumetric that runs with the bed levelling just before the actual model prints and it appears that it may be better…cant be sure as it’s still printing at the moment, the test lines it printed at the start were certainly a LOT thicker than when it ran without the auto setting…
I think you got the wrong suggestion in this thread. Your PETG isn’t able to be printed at 25mm3/s volumetric speed. Even if you do the Max Flowrate calibration and it reaches 25mm3/s, it does not mean there aren’t any issues like under-extrusion. You need to measure the line width with a caliper tool.
Only recently a breakthrough in High Flow PETG has been achieved and it does not seem that you have this filament.
PolyMaker PETG → 8mm3/s at 260C
FlashForge PETG Pro → 12mm3/s at 245C
I don’t know about your filament… Maybe use the Generic PETG filament settings
The filament is Elegoo RAPID PETG …
the line width was chosen as the best overall from the test print, the other settings likewise from the various test printouts
So, should I reduce the volumetric flow to, say 10 and if so would that not be overridden by the auto flow calibration run immediately before printing ?
The item I just printed using auto volumetric flow calibration still had the same problem…but why is it ONLY when printing side to side and ONLY on the front facing faces, irrelevant of the width of the item printed…also bear in mind I had the same issues with the Creality PETG before Amazon stopped selling it
I reduced the volumetric speed setting to 10…and it appears to have printed perfectly with the layers bonded as they should be on all faces :smile:
It is my understanding that the volumetric speed setting overrides and reduces the maximum printing speeds …so, should I leave it at that or reduce the actual print speeds here ?
the spec of the filament says print speeds 30 - 600mm/s so I had set them just under mid-way
I should add that not only are they stuck firmly but the overall finish is excellent and smooth
maybe someone could explain the differences and interactions of print speed vs volumetric speed…and also as to why all the calibration models suggest a higher speed?
So, taking all of the above into account, exactly how do I determine the optimum print speeds and volumetric speeds etc.? … the built in calibration methods obviously arent working…and there are just too many variables to contend with
I re-ran the max volumetric flow again with settings of 15 - 25 @0.5mm step and it printed pretty well all the way to the top with a minor glitch at 12mm up, looking at the slicer at this point shows the max flow rate of 20 …which is what I had it set to !..but the layers above that are all good so it is suggesting it will print well up to and possibly past MFR of 25!
First, I’m glad you slowed down and had a great print!
Re: marketing claims, unless the speed rating says “$x speed AT $y temp AND $z layer height out of a $name printer/hotend” it’s probably best to ignore the marketing dept. There are realistically (and sadly) no regulations, laws, rules, or enforcement to control whatever the hell companies claim anymore. Those settings are, however, crystallized in code for bambu filament in bambu profiles, presumably by someone at bambu who did some tests, so that is probably the starting point I would use — even if it’s not bambu brand filament! Bambu is in the business of making filament too, so their software won’t let those profiles rot.
[Edit: This also isn’t an endorsement of one filament vendor over another, and for what its worth like a quarter of the stuff I print with is elegoo also. I love their pink! ]
I had a big long thing typed here about how to determine optimums, but like, there’s way too much nuance and interdependency of the settings. Here’s my honest advice.
Pick a small object that you love. It’s nice if that object displays good tests of a printer (an overhang or two, retraction areas, etc) but really, as long as it’s something you love, you will notice the subtle nuances. I’m about to lay a curse on you: The first 10-20 grams of every spool you ever buy is gonna be paid as tribute to this object. All those reels you see on amazon? No, they’re not 1.000kg, they’re now 0.980kg. Print a lot of them, make a shelf, label them, and smile at the ones that turned out melty anyways as you adjusted parameters.
