Overhang support issue
Im having an issue with overhangs that aren’t ignoring my command regardless if i paint overhang and use normal/manual only it will still pick up my support in middle off item as picture shows (little circle overhang ), and yes i have small overhang disabled this brings my change filliment to 13 times instead off the requested 3 times
![17325061265948411772687988755312|666x500](upload:/ /6wKZaz68A4ly4NceDtG0JemE6Xc.jpeg
Can you upload the .3mf as it will be easier to explain how to fix this issue.
I’m afraid you may not get many people to jump in and want to help you if you aren’t willing to put in the effort to illustrate what you mean. Please take the time to learn how to do a proper screengrab. Here’s a tutorial. 7 Easy Ways to Take Screenshots in Windows 11 | PCMag
Once you’ve done that, if you can post a screengrab of the model at the angle you’re referring to as well as the sliced version, then you’ll find that people will have an easier time understanding your objective. The solution may not be just the setting but also how your model is oriented on the build plate. Again, a true screengrab will show this.
Last and not least, upload the 3MF and folks will be able to do a more detailed analysis of the model and how you laid it out and your settings.
You’ll find that you’ll get more people willing to help you out if you put in more effort to communicate the information needed.
Bucket_-_Copy.3mf (163.1 KB)
can somebody help me out with this file when i use support normal/manual and i use a painted support for some reason i still get some over hangs i don’t need, this will put my filament to 13 changes instead of the 3 i only need to support the very top off bucket in the back. but it wants to add my ABS Filiment support to middle circle as well, and i don’t need it there . Thanks
It’s really simple.
Click on the model and use the “Support Painting” tool.
Right click and paint where you don’t want support.
Change to tree supports and sliced the model.
Bucket_Support.3mf (172.9 KB)
