New P1 Series Firmware Available for Public Beta Testing!
We’re excited to announce that firmware V01.09.01.23 for the P1 Series is now available through our Public Beta Program.
How to Join the Beta
To access the beta firmware, simply join the Beta Firmware Program via the Bambu Handy app under Me → Beta Firmware Program.
Once enrolled, the update will be pushed to your device gradually.
Want to Switch Back?
You can leave the Beta Program at any time by disabling the option in the app and installing the latest official firmware version.
New Features
External Spool Multi-Color Printing: Added support for multi-color printing using the external spool. Users can now manually swap external filaments during the printing process to achieve multi-color results (Requires Bambu Studio 2.5.2.65 or higher).
Automatic Drying Presets: Added the ability to automatically match official filament drying presets when using AMS 2 Pro or AMS HT for drying.
Chamber Light Memory: Chamber light preference settings are now saved after power-off.
Feature Optimizations
Security Update: Included critical security patches.
Local Files Reprint Logic Optimization : Added AMS detection when initiating prints from local history. If no AMS is detected, the system will now default to the external spool option.
G-code Files Printing Logic Optimization: G-code file printing now defaults to single-color printing via the external spool.
PA Parameter Memory Fix: Fixed an issue where power cycles could cause the Pressure Advance ( PA ) parameters of filaments inside the AMS to be overwritten.
Power Loss Recovery Optimization: Fixed occasional abnormalities in the “Power Loss Recovery” function.
UI Display Fix: Resolved an issue where the interface would occasionally appear blank following a version update.
Third-Party Filament Drying: Fixed an issue preventing drying cycles for non-official filaments when loaded into AMS 2 Pro or AMS HT.
Notes:
Bridge Firmware Requirement: If your P1 series printer firmware is below 01.09.01.00, you must first perform an offline upgrade to the “Bridge Firmware” (01.09.01.00) before upgrading to any version higher than that.
Recommended Accessory Versions: To ensure optimal stability and user experience, we recommend updating your AMS units to the following versions:
AMS: 01.00.06.83
AMS HT: 03.00.21.29
AMS 2 Pro: 03.00.21.29
