P1P + AMS 2 Pro. What is needed
If I want use AMS 2 Pro on P1P, can I use original AMS holder?
From hardware I need:
AMS 2 Upgrade kit
Will this work together with P1P?
You can use the AMS Filament Buffer shown in the Upgrade Kit, but if you think you may get another AMS, AMS 2 Pro, or AMS HT in the future, I would suggest you buy the AMS Hub instead.
The Filament Buffer is meant for a single AMS only.
But will AMS holder work with AMS 2 Pro and P1P?
I stand by my comment but one thing you need to check is how to mount the buffer or hub regardless of your choice. The P1P does not have the enclosure like a P1S. The rear shell is formed to accommodate the hub or buffer but I do not know how that is accomplished with the P1P since it is open. There is a picture here that I think is a P1P but I have never seen one in real life.
I believe this is a P1P so you should be in the clear. I’d also recommend buying a roll of the PTFE tubing in the event you need to reconfigure the current routing path.
I keep wanting to get this but its always out of stock
The hub is not needed. The buffer and the 4-in-1-adapter do the trick.
