P1P - Print plate sends to printer but requires manual start
Started a while back and can’t seem to figure out what’s going on. I can successfully send the print over LAN but it doesn’t initiate the actual start of the print.
I have to go to the printer and select the print from the SD card and manually start it. After which, everything is fine. But it used to just start the print without that last step. Any ideas on what is going on?
Send does just that - it sends the g-code to the printer’s storage.
You need to Print to actually execute the g-code.
At some point ‘a while back’ I think you changed your preferred action.
Click the green down-arrow, select “Print plate” to change the action of the button. Then that button will send AND print.
I am doing Print plate not send, the issue is it’s acting like send
