P1S + AMS2, few questions while waiting for the third package
Hi everyone.
This week I ordered a new P1S with AMS 2 Pro buffer combo. In just 2 days the printer and the AMS were delivered and now I’m waiting Monday for the accessories box (yesterday was a national holiday here in Italy…). Because I need the buffer with its 4-pin cable to connect and test everything I started studying how and where to place the printer.
I was wondering:
  1. How much is the minimum radius for the PTFE to avoid excessive friction?
  2. Are there any stl with some bending guide to help with the previous question?
  3. The AMS2 Pro has a venting hole on the bottom, it will help rasing the AMS2 a little or is designed to work wt that height?
  4. When using the dry feature can I put different filaments in the AMS (like PETG and PLA)?
  5. Any tip/trick/issue/miracle to do or print before assembly or printing hard?
Thanks
If you have plans to add more AMS devices to your setup you will need the hub. The hub is for single AMS use. People put in splitters and BL even sells a 4-way splitter but the hub is designed for a single AMS.
  • I have very large loops on my 3 AMS devices. You can also use the Z-axis. Nothing says the loops need to run in a straight line. I just want the loops behind the machines. I also have a pretty compact 3-drawer rack the 3 AMS’s sit in so I need enough slack to pull out a drawer without kinking or tugging on the tubing.
  1. Are there any stl with some bending guide to help with the previous question?
    *Never seen any but also have no need.
  2. The AMS2 Pro has a venting hole on the bottom…
  • There are 2 vents which are part of the drying system so you want the space under the AMS to allow freedom of airflow under an AMS 2 Pro
    1. When using the dry feature can I put different filaments in the AMS (like PETG and PLA)?
  • Yes you can put various types of filament in at once but from the control side of things you can only configure the AMS for one filament at a time. If you choose a filament configuration that requires 8 hours but you have a 12 hour config filament in another slot, that 12 hour filament will be short 4 hours. Same applies to temperature configuration.
Tips and tricks?
  • Buy spare parts and definitely spare nozzles. Customer service spans the globe and there in a very long lag in communication between you and BL in the event you have a warranty issue. My first P1S went crazy and it was a 5 week process to get to a new replacement printer
  • Use the Technical Support Wiki. Many of the problems and technical questions you will encounter are covered it the wiki.
    Bambu Labs Wiki Homepage
