Hi i have a p1s and its jamming on the z axis when it gets to about where the wiper bin starts and then it looks like its coult on something it makes strange noise and moves less ech time going up even though i use the by 10 every time ive linked sum videos of issue
The first picture shows a massive issue and you don’t really talk about it. The z-axis lead screw is not seated inside the bearing, this is disastrous, so are we to assume its reseated before the videos showing the tests? Which don’t show much, one would want to see down the z-axis as the screws turn to see if they are true.
It looks like the z lead screw has dropped out of the bearing. Check the bottom of the printer where the z lead screw is attached the the pulley. Here is wiki for doing this.
@user_3663498702 - that excess grease will cause you all sorts of bed adhesion issues if it gets on your build plate. Silicone-based greases are difficult to completely clean off too.
Best to keep build plates safely out of the way of flying grease when lubing up and use just a small amount of grease evenly applied.
Lol the guy on bambu suport tolled me to try lubing the screw and belt he dident noice it pick about lead screw had come out lol but i have now cleaned most of printer lol
