Today I had a nozzle clog in a P1S. Standard needle unclog didn’t work, so I did a cold pull which cleared the clog.
Since then, the nozzle constantly leaks filament if there’s any loaded in the hotend. I’m heating the nozzle to 250c as I would with a cold pull, but instead of the first line of filament being extruding, then stopping with the rest left in the hot end, it just keeps going. It’s much slower than intentional extrusion, but is sufficient enough to be a constant stream. If left alone with the nozzle heated, the hot end will completely drain and it will need several extruder activations to push enough filament back into the hotend.
I’ve disassembled both the hotend and the extruder. There was no noticable debris inside either, and the hotend is clear enough inside that I can see through it.
The extruder appears to be working exactly as expected, so I believe there is an issue with the hotend and/or nozzle.
Something of note is that usually when manually loading filament for a cold pull, I have to activate the extruder 8 times in order for filament to be pushed out the nozzle. At the moment I only have to do this 5 times, and the filament sort of spits/bursts slighty out of the nozzle. I’m assuming there is a pressure issue and as soon as filament enters the hotend it’s draining out of the nozzle.
As I test, I loaded some PLA at 250c by hand, changed the temp to 0c, then manually used the cutter and backed off the extruder to remove the loaded filament, leaving only what is in the hotend. By the time the hotend fully cooled and could be removed, there was nothing left inside.
I don’t have any spare P1S hotends on hand, so is there anything else I can try in the meantime? The nozzle has been heated and then cleaned with iso and a brass brush, is visibly clean and can be seen through, so I do not think there’s a debris issue. The hotend is securely seated in the correct position and is screwed in properly.
Maybe it’s just fully cooked? Could I have damaged it with the unclogging needle?
