Every time I power on, there’s a loud noise. Sometimes during printing, there’s also noise. After printing is finished, even when I manually set the case/component/auxiliary fans to 100%, there’s no noise,so i think there was not caused by fans…. how to solve this problem of the noise…? Thanks
have talked to there live chat
what does you mean? thx..
have you talked to Bambu labs live chat they can probably help you but i can look into this for you if you want
i am looking into this for you
have you printed without the fans see if it makes the noise
Yes..they replied in below”
We sincerely apologize for the inconvenience you experienced during printing. Based on the information you provided, we suspect the issue may be related to abnormal noise from the motors. Could you please refer to the following Wiki article to check whether the A/B motor noise is the cause of the problem?
Additionally, it would be greatly appreciated if you could record a close-up video of the issue, which will help us further diagnose and resolve the fault more efficiently.
but i dont want to reinstall of XY motor currently..so complex…![]()
the problem was occured when turn on of the 3d printer, for a while 10mins during printing also has noise, but after around 10mins later , no any noise.
i also tested to turn on 100% for all fans by seperately, no noise
does it make the noaise just when its printing
i think that is no noise becoz i just print a one thing after turn on of the printer.
not sure print more will be have noise or not.
so just when printing twentyfive
try lubeing your x and y axis
you fix it yet twenty five charectors
