P1s multicolor layer shift first color change
  • Printer model used
  • Slicer settings used
  • Type of filament used
Hello. I am Korean.
First of all, please understand that my English is not good.
I am writing this because my p1sc has recently had a problem.
At some point, when using multicolor, the x-y did not match the first layer replacement.
At first, I thought it was a simple error and reprinted, but the problem was the same.
I applied for a ticket and adjusted the tension because they said the belt tension was the problem.
However, the problem was the same.
Only the first layer did not match, and after that, it printed normally.
I cleaned the belt and the inside again.
I tried updating the printer, downgrading it, and using the slicer and Orca Slicer.
I tried everything I could, but I could not fix this problem.
I searched for people who had the same problem as me on various sites such as the bambulab forum and Reddit, but I could not find a clear answer.
I thought about it and tried many things for a month, but I still could not fix it.
I am currently using the belt tension adjustment output and have also modified the G CODE.
I added G28 X Y, and the current Y-axis is normal, and the X-axis is about 0.2mm different.
If you know how to modify the G CODE in this state to output normally, please leave a comment.
Or if there is a physically possible solution, please let me know.
Thank you.
