P1S Nozel Maintenance
My setup to unclog and do maintenance on P/X series Nozels. Or in fact any other nozel/heatbreak!
Please tell us more. What’s the WD-40 for? What maintenance are you peforming? How do you do it?
The SMD is to heat the heatbreak to the temperature i need to flush all the contents inside (tpu left overs, Wood filament particles, etc). The WD4 is do clean all the debris outside and INSIDE the nozel, its a wondefull gum and wax remover!
And no I don’t contaminate nothing on the buildplates! Before any print and after the cleaning I flush the heatbreak with the filament i’m going to use in the printer! Also WD40 prevents bad quality filaments from sticking to the nozel tip for some prints, even if the temperature is low (thats when u see the filament stick to the nozel more often as it curls up).
Do you have clogged nozzles?? I buy them all :wink:
I mean…I have around 50 X1/P1 hardened hotends in excellent condition…
Cudos! Keep them all then. 50 its a printfarm dream!
The last one in the row its my highflow model that cant take from 0.2 to 0.8 if needed! Hardened, Stainless, coper or rubi.
Definitely a lot more effort than I would be willing to put into it. I just dont see the benefit.
Run a nozzle until it is worn out, then give it a viking funeral out on lake Erie on top of a scaled up benchy.
Naa i prefer to spend that money on beer! The BL hardened nozel is 3.5 years old and i lost the count to the hours it printed Glow in the dark/wooden filaments/PMMA and its still going! But i understand your point!
You could grind it down or drill it out and make it a 1.8 nozzle. Never done it personnally. Or maybe shoot a stream of Lysol spray thru it (with out changeing nozzle) and light it… hmmm.
Edit: Ok, don’t do the Lysol thing IN the printer, I was thinking of if you were going to toss a nozzle..
That’s not a repair technique—that’s how you turn a printer into a smoke machine with a warranty claim!
Let’s keep the pyrotechnics out of the workshop!
