Hi Folks!
New to the forum, new to Bambu’s, but not new to 3D printing having had a few Prusa’s over the years.
Loving the Bambu P1S so far, but have encountered some troubles printing in vase mode which I’m hoping you can help me out with.
I’m getting excessive filament buildup on the nozzle, which eventually falls off and embeds in the print ultimately ruining it. This is only occuring when printing in vase mode.
I’m printing using PolyTerra PLA, have tried several different models and have currently resorted to a simple cylinder shape for troubleshooting and getting this sorted out.
Details:
Filament: PolyTerra PLA white
Nozzle: 0.4
Slicer: Orca
Slicer settings: standard PolyTerra filament profile, standard P1S profile 0.4mm nozzle
Things I have tried:
Reduce print temp: the standard profile temp is 220c. I’ve reduced this all the way down to 190c. This did have a positive effect on the amount on buildup on the nozzle, however getting down this low I’m seeing layer adhesion problems between the base layers and the first vase layers.
Flow rate calibration: I checked the default flow rate for accuracy using the cube test, which confirmed the standard profile settings were accurate. (edit, added)
Reduce flow rate: no effect, even at 0.75 I’m still seeing nozzle buildup
Increase Z offset: added 0.01 Z height offset to lift the nozzle a bit higher. I started at 0.4 offset and reduced until I had a well printing first layer. Still, I get nozzle buildup.
Reduced print speed: down to 50mm/s, buildup still occurs.
This buildup is only occuring to this extent on the Bambu printers. I have a couple of Prusa MK3s’s which I’ve been testing the same models on and I’m not getting any nozzle buildup (or very minimal) on these.
At a bit of a loss here and could really use some help!
Thanks
