P1S Z Homing
P1S - lately I haven’t been able to print. Message says Z not honing. I’ve followed the instructions: making sure there are no bits of filament or other waste blocking anything, plate is square on bed, nothing is sticking up or out and the plate isn’t touching the sides anywhere. I have a feeling this may be a common issue and that someone has the solution? If not, next stop servicing.
Incidentally, the printer isn’t detecting the filaments correctly, either.
Have you tried putting the printer on its side and inspecting the Z belt on the bottom for obstructions? You can also move the belt by hand and see if it moves smoothly. You should probably tension the Z belt while you are at it.
