P2S Dynamic Flow Calibration issue?
Sorry for the stupid questions. I’m new to 3D printing.
P2S firmware 01.01.03.00 (haven’t tested it on other firmware versions)
Filaments BambuLab PETG-HF (haven’t tested with others).
Step 1. Run automatic dynamic flow calibration. Select all four filaments (AMS 2 Pro). The first one (A1) has a coefficient of 0.024, the others (A2-A4) 0.030-0.031. Okay, but no.
Step 2. Run automatic dynamic flow calibration again. Select only the second filament (A2). After calibration, the coefficient for A2 became 0.025.
Step 3. Run automatic dynamic flow calibration again. Select the third (A3) and fourth (A4) filaments. After calibration, the coefficient for A3 became 0.025, and for A4 it remained 0.030.
Step 4. Repeat step 1. And again, get a value of 0.024 for A1, and 0.030-0.031 for all the others.
How is this possible? It seems like the first filament on the list is calibrated correctly, but all the subsequent ones are incorrect.
If perform calibration separately for each filament, the value for all is between 0.024 and 0.026. If you run everything in one test, the first one has the correct value, and the others are incorrect.
Firmware error or hardware problem ?
