I recently got an extruder motor overload warning during a print on my P2S (had it for 1 month), after removing the toolhead cover, manually cutting the filament ( to confirm it was cut) I tried to remove the hot-end. I removed the silicone boot and unclipped the fastening. The hot-end appeared it had got extremely hot as showed signs of overheating, It would and will not come out from the tool head. I do not want to put a set of pliers on it and force it as I do not want to damage the tool head. I have attached an picture showing the heat damage. Does anyone know how I can remove it without damaging the toolhead? Any help would be greatly appreciated.
you donāt need to go that high, itās not filament that is making the nozzle stick, itās gas residues that solidify and become sticky - i do this all the time in my h2d
Just heat it enough that it comes lose, try 120 and if it is still stuck go higher, I always go to the same temp as the filament print temp because it lets me wipe any excess off easily
Managed to free it at 130 deg, thanks. I pulled out the old filament from the hot end quite easily and luckily I had a spare to replace it, the printer is up and running again. Is it possible to salvage/clean up the old hot-end? Can I heat up the outside and try and wipe off the burnt on filament? Your advice would be appreciated, thanks.
You need to figure out how to remove the gunk regardless, because you do want to clean off the surface on the extruder that it mates to as well, or the next one will just get gunked up too - at that point just clean both of āem off.
Currently trying to clean now, using IPA and a brass brush, the extruder surface cleaned fairly quickly, the hot-end is steeping in a jar with IPA, hopefully should soften up the āGunkā. Thanks.
If itās PLA alcohol isnāt going to help - PLA doesnāt dissolve in most solvents, and the ones it does dissolve in, you donāt want to have anything to do with.
