Where can I find the internal files that came with P2S?
Tried Bambu Lab Wiki, it doesn’t have them.
Tried FTP into the printer, but it FTP does not show any files, even when switched to LAN+DEV mode.
Pop out the SD card and load it on your PC/Mac, then open the models folder. It will look something like this:
Edit: I am wrong. See @JonRaymond’s post below this.
I don’t think the P2S ships with a SD card like the P1S and A series. Print files are cached on the controller like the X and H series printers. You won’t be able to access the internally sliced files on the P2S.
I would assume at some point they will be released and added to the wiki.
Is there a reason you need to access them?
there’s a few models/gcodes are new from the P2S, just want to take a took at them. Especially the filament holder, seems like something that I can remix.
I don’t get why Bambu removed ftp access to these files.
The gcode on the machine isn’t a model. You would be able to view it in the preview tab but that is about it. You would get more information from printing the file and remix it from measurements.
I don’t think you’ve ever been able to ftp access the internally sliced models from the X or H series. The P2S uses a controller similar to these machines.
do you need this files?
P2S have more files than these, so some are missing
