It says:
"printer_series": "series_x1",
so its not a p series its a x series. ![]()
Found this in the config of Bambu Studio:
"00.00.00.00": {
"display_name": "Bambu Lab P2S",
"print": {
"ipcam": {
"resolution_supported": [ "1080p" ],
"virtual_camera": "enabled",
"liveview": {
"remote": "tutk"
"file": {
"local": "local",
"remote": "tutk",
"model_download": "enabled"
"nozzle_temp_range": [ 0, 300 ],
"nozzle_replace_wiki": {
"zh": "https://wiki.bambulab.com/zh/h2/maintenance/replace-hotend",
"en": "https://wiki.bambulab.com/en/h2/maintenance/replace-hotend"
"bed_temp_range": [ 0, 110 ],
"support_motor_noise_cali": true,
"support_tunnel_mqtt": true,
"support_mqtt_alive": true,
"support_command_ams_switch": true,
"support_ssl_for_mqtt": true,
"support_cloud_print_only": false,
"support_1080dpi": true,
"support_prompt_sound": false,
"support_ams_humidity": true,
"support_auto_recovery_step_loss": true,
"support_bed_leveling": 2,
"support_update_remain": true,
"support_timelapse": true,
"support_filament_backup": true,
"support_chamber_fan": true,
"support_aux_fan": true,
"support_send_to_sd": true,
"support_print_all": true,
"support_print_without_sd": true,
"support_flow_calibration": true,
"support_auto_flow_calibration": true,
"support_build_plate_marker_detect": true,
"support_build_plate_marker_detect_type": 2,
"support_lidar_calibration": false,
"support_nozzle_offset_calibration": false,
"support_high_tempbed_calibration": true,
"support_clump_position_calibration": true,
"support_ai_monitoring": true,
"support_first_layer_inspect": true,
"support_save_remote_print_file_to_storage": true,
"support_chamber": true,
"support_chamber_temp_edit": false,
"support_extrusion_cali": false,
"support_user_preset": false,
"support_ams_ext_mix_print": true
"fan" : {
"0" :
"description": "",
"2": "Right(Aux)",
"10": "Left(Aux)"
"1" :
"2": "Right(Filter)",
"10": "Left(Aux)"
"special_cooling_text" : "Cooling mode is suitable for printing PLA/PETG/TPU materials."
"model_id": "N7",
"subseries": ["N7-V2"],
"auto_pa_cali_thumbnail_image": "fd_calibration_auto_n7",
"support_wrapping_detection": true,
"compatible_machine": [],
"printer_type": "N7",
"printer_thumbnail_image": "printer_thumbnail_N7",
"printer_connect_help_image": "input_access_code_x1",
"printer_use_ams_image": "ams_icon",
"printer_ext_image": ["ext_image_n7"],
"use_ams_type": "generic",
"printer_arch": "core_xy",
"has_cali_line": true,
"printer_is_enclosed": true,
"enable_set_nozzle_info": false,
"support_safety_options": true
