P2S nozzle clogged both ends. Help to clear
Total newb. Clogged nozzle (.4 mm). Melted filament out bottom. Cut off piece of filament sticking out the top. How do I unclog? Is this what a cold pull is for using the control panel?
you can try a cold pull. Would be the first choice.
Yes, cold pull would be the answer here is the official bambu instructions:
Thank you bth. i figured. Had a bit of a problem removing the PETG tubing b/c pressing down did not trigger its removal. I was a bit cautious in wanting to press down harder, but that likely s all I need to do.
