P2S PETG on CF Plate
Hello all,
I use Bambulab PETG HF filament and the default profile but moving the bed temp up the 80C and just find that absoloutely nothing PETG related sticks to the CF plate on the P2S. I have washed the build plate, and it works perfectly on my A1 so it is not a problem with the build plate as the issue also occurs with the PEI smooth plate from bambulab. I have also turned the heat fan off and many other things but nothing seems to fix it.
Anyone had any luck?
Lots of issues recently with P2S and not sticking, someone will come along and tell you you need to clean the bed soon lol.
Two threads to check
CF is harder to print with and does wreck your nozzle quickly.
If its a new nozzle, and you have issues, then start by checking your bed and nozzle temp for first 3 layers, also your fan settings.
Neil
