50 seconds per nozzle … or 5 min for all 7 tools, add more time if you need to unload all 7 before that. I would not call it drama, just friction and less convenient than throwing in the spools and walking away. It comes down to how much you print and how often you swap filaments. I have designer friends that print a lot with different filaments with H3C that are already complaining about the lack of retraction on it. When you work with the machine all day long its a pain point when you are used to the previous AMS generation workflow.
And it was a decision made to reduce cost and complexity and increase reliability for something which is otherwise nothing but a very minimal convenience. Adding motors provides zero benefit to the functionality of the printer.
Some outrage over a small amount of added work is nothing compared to the inevitable failures, repair claims, and screaming users they’re saving.
If you don’t like it, go buy the snapmaker. If you think the snapmaker is a better value, go buy that. If you think this is a worse product because you have to actually get up and participate then by all means vote with your wallet and buy the other printer. But don’t forget that the snapmaker still requires you to go to the printer to change rolls.
20 seconds of effort is a huge problem until you’re back complaining that the motor failed in a few months, as these things commonly do.
I for one would rather have vastly increased reliability. The AMS units are cool but they’re also a failure point.
I spent weeks back and forth trying to get my ams ht working again. I just replaced the main board and now it’s back up.
Imagine if that ams was required to even use the printer, which would be the case for the P3 and H3 machines in certain types of faults.
By that rational we should all be using printers with no features, just a nozzle and an external spool, something simple like Ender 3 but built by bambu. The answer to “this does not work well” should not be “remove that” if you want progress. I have around 25k hours across 6 printers with AMS systems. AMS 1, 2 and HT. The only failures I had are worn out funnels on AMS 1 from CF filament. Just some anecdotal info, sorry you had so many problems with yours.
PS: As a side note, AMS 3P and 3H have plastic funnels, not ceramic like AMS 2.
Ah, you haven’t had failures yet so they’re not a concern. Got it.
See the flaw here is thinking that you need something just because it used to exist. If it adds nothing but increased risk of failure it should be removed if it is no longer needed. Oh, it saves a few seconds?
How valuable is it to save half a minute on a roll change if it results in 6 weeks of down time as Bambu throws parts at it until it works again, one part at a time?
In this case it’s no longer needed. The pros are outweighed by the cons.
I was just saying across 6 printers and 8 AMS units Ive had no failure in 25k hours. Like I said some anecdotal evidence, nothing more.
I agree that auto-feeding is not mandatory for tool changer but its a nice QOL feature. Why do you think the competition U1 and K3 have it? Why do you think they have it on H3? Because QOL features matter. I can promise you with all the feedback they received with the release of P3C the next generation will have it.
Sorry but that explanation don’t convience me at all. Following this logic, Bambu should remove other similar features because every feature is a possible source of failures and issues. Or can simply get it done right, like mamy times before. Yes, it’s not a deal breaker, but lets be honest - they remove it mainly to cut the costs. H3C has auto-feeding.
Filament track switch offers zero functionality to the printer. It’s a 100% convenience item. I haven’t bought one and I won’t, mainly because I use a lot of stiff filaments and don’t like the extra bends and resistance on loading. People want convenience and they’re willing to pay for it. If I did nothing but PLA color prints I would probably get one if it was hassle free. Most of the filaments I use on a daily basis are CF or GF and yes I use them in the AMS. I do hope at some point Bambu offers ceramic funnels for the AMS 3H as un upgrade for PETG/PCTG CF/GF filaments that still go through the AMS.
I personally haven’t had an AMS fail on any of the 7 AMS units I have (not including the AMS 3H). I also have spare parts so I’m not down for 6 weeks. Other than PTFE tubes I haven’t needed any of the parts for the AMS that I bought. I absolutely hate and despise having to manually load filament inch by inch through a PTFE tube. It’s actually one of the reasons I bought the TPU feed assist module. And yes, I expect auto load on all printers I buy now. With the H3C the auto load is a life saver. Today alone I loaded 15+ spools switching filament for different prints. My time is valuable. It’s not the 50 seconds to load one filament, it’s the F’ing waiting around when loading multiple filaments that I have no patience for.
Normally I don’t do this many colors but I have a new toy and Christmas and birthdays (for my family) are coming up so I’m switching a lot of filaments. On the H3C I drop in 5 spools and walk away. That is worth it to me if the AMS 3H ends up being half as reliable as my other AMS have been. I value time over money within reason and I feel most people do as well. That’s why you see so many people with crazy amounts of AMS. They really only need maybe 2 or less for most projects. They buy 3 or 4 because of convenience.
As a side note. I swear I get PTSD from my years of loading filament inch by inch on my old Tevo Tornado and Robo3D R1 printers. On the Tevo Tornado I even replaced the extruder with a direct drive but still had long tubing because I added a filament run-out micro switch I custom made and programmed into Marlin. It saved prints but you had to feed filament from a drybox to the filament micro switch box. Then manually guide the filament in that box around the micro switch (with needle nose pliers) into another tubing to the extruder. Wow how I don’t miss those days. “I’m not going back man… I won’t do it…”
Fact: Those faults can be entirely eliminated without compromising the actual printing capabilities of the machine. Adding the motor does not provide one single benefit to the print process itself.
Fact: Ditching them saves money on the printer, reduces cost to the customer, and saves repair costs.
I’m surprised they even still bothered with the feed motors on the H3C tbh.
Having sat through too many pfmea meetings to identify risks of a product and preemptively come up with ways to mitigate those risks via design changes and product simplification I can assure you that they didn’t remove a feature lightly.
Any competent business should know that the loss of any feature at all will drive consumers out to the shed to get their pitchforks.
Likewise any competent business owner running a printing business should know that buying a consumer grade printer instead of a 5 figure unit from someone like stratasys is going to come with sacrifices.
People losing their minds over a feature that’s fundamentally useless to the proper operation of the printer is deeply amusing to me. It’s not like the other ams takes zero time to refill. Less, sure, but it’s tens of seconds less. Truly life altering. Surely the additional 8 minutes lost over 15 rolls per day will cause one to go bankrupt.
