Many thanks again for your response!
Since I only have PLA and PA6 right now, and I don’t mind to spend some extra PA6 on this test, allow me to summarize again, what I should try (forgive me that I am detailed and may seems to not getting what you say, I promise isn’t the case just want to have full grasp of the concept before I start the test):
- I am adding a base layer using PA6 to my object using the technique in this video: https://www.youtube.com/watch?app=desktop&v=wQqtQQzrvM0
- Since Bambulab PA6 bed good adhesion requires 110c bed, I print 1 layer being 115% larger then my object, then I lower bed temp to 85c and print my object with support.(on the bottomm as you can see on my photo earlier, this is critical for nice removal on this part)
Correct?
No, I dont anneal the part, I would like to avoid that due to my technical and space limitation.
Once again, many thanks for your help and patience
