Hi all,
I’ve run into a frustrating issue in Bambu Studio (v2.2.1.60) that I hope others have experienced or found a workaround for.
What happens:
- I import a 3D model into Bambu Studio.
- I use the Paint tool to color certain areas of the model.
- I then need to cut/split the model because it’s too large for my build plate.
Problem:
As soon as I perform the cut, all the painted areas completely disappear.
Attempts & notes:
- Brush-Paint is clearly treated as an overlay, not as actual object color.
- Per-object color or modifier-based color seems to survive cuts, but brush-painted areas do not.
- The issue happens consistently with 3MF files that contain painted areas.
- I’ve tried downgrading to version 1.7.7.89 (suggested on the Bambu forum) but the problem persists.
Questions:
- Is there any reliable way to preserve brush-painted areas when cutting a model?
- Are there other slicers (or older versions of those slicers), or workflows that correctly translate 3MF painted areas, so they don’t get lost after cutting?
- Are there other tools that can generate/convert 3MF’s that do not loose Painted areas after cutting? (As an intermediate step between Painting in Studio and Cutting in Studio, maybe by translating painted areas to objects)
- Are there other tools that can cut 3MF’s without losing Painted areas after cutting?
Thanks in advance for any insights or workarounds!
