Pause / Change cOLOR
After setting up a pause layer at 7, the printer only stopped at 10.Also, when Iclick on the rectangle to confirm the puase point, I seem to get varying layer positions.
Any ides? Can the layer pauses be done typed, or are they all set by mouse?
and can u make changes after the print has been downloaded and printed started? I guess only manually?
Thanks.
Right click and then press jump to layer in Bambu studio.
How does that work
. I se th option but not sure when / how to use it. A change color is at layer 22. I’m on 18. Each layer need to be printed.
Check for ‘Bambu Studio Color printing without AMS’ from Ashley’s Print Shop on YT. Either I misunderstood, or apparently you can’t post links here.
The color switched this time for some reason.
Other quetions stand - can u type in the color change layer?
Can change anything once the print is downloaded?
