Good day dear.
I’m trying to figure this thing out. Here is an example of a model printed in vase mode at a fairly high speed.
Here, the perimeter speed rests against the maximum volume velocity of the material. In my case, 22 mm3/s. And that’s what the problem is. If you greatly reduce the speed of the perimeters to somewhere around 50 mm/s, then everything is printed more or less normally. But at the same time, during the test for the maximum volumetric speed, the object in it is also printed in vase mode without problems at speeds up to 30 mm3/s. And according to the width of the layer that is there, it is somewhere under 150 mm/s. I set the same layer width as in that test object and still got defects on this box.
I think it’s because that test object has no sharp corners at all. Is it possible somehow in the slicer to take into account the presence of corners in the model to automatically take this factor into account, instead of reducing the overall speed of the perimeters manually?
