PETG-Cf and Support, print issues
Greetings everyone,
hoping to find an answer here for why this print is seeing a problem on the same spot every time.
Im printing PETG-CF with Support for PETG as the interface.
Just after the support material print on the overhang it starts over extruding massively. Interestingly it stops over extruding roughly when it stops needing the prime tower. So the over extruding or what ever its called is limited to roughly the layers where its building the prime tower but not needing to use the support material. Approx between layers 50 and 270. Photo from slicer (changed to a red material so you can see more contours) and photo of the issue attached.
anybody know whats going on?
Thanks a lot
