Evening everyone,
I have a spool of Sunlu PETG - Digital Blue to be specific. I’ve been attempting to print a Floating Shelf w/Bracket from Maker World. It prints fine for ~ 2 hours, then the print heads goes all the way to the left, does 2 scrapes then it runs to the right, cuts the filament and then promptly Errors out stating an Extruder error. If I select on the touch screen, No Issues, Continue the print. It restarts ( a slight layer line is the only impact) prints for maybe another 90 minutes and does the same actions and same error message. If I use the same model with BBL PETG - Silver, it prints it just fine with no issues, I’ve several copies of this that are perfect. But, change up the Filament and this happens. Thoughts?
Thanks. Aaron
Try a different AMS slot. I had similar issues and found I had a warn AMS inlet.
Which printer model is this?
@mugglesmuggle , Its an A1. with AMS Lite.
Did you re-slice the file to use Generic PETG instead of Bambu PETG?
@mugglesmuggle , I dont think I did. I’ll give that a go and report back. - Thanks.
Aaron
