I agree with the fact most plastic allow moisture to slowly get inside, this has never been in dispute, as that’s why they ship silica gel packets inside most sealed plastic bags, to absorb the moisture that gets in to the bag. That’s also why you should put silica gel packets in with your spool in a sealed bag or box. As moisture will get in, no denying that. Silica gel is a cheap option, rechargeable silica even better.
Chances are a new spool from a decent brand is fine to print with, but depending on your environment, how you store it, lots of variables actually you need to adopt a care routine for your filaments, as once out of their factory sealed bag they will absorb moisture, no stopping it.
If you use up the spool quickly, I have done this a few times, 1KG for me is gone in about 30 hours then I never had to dry it at all.
But if your filament sits, some of my colours I hardly use, or translucent for example can sit for months without me using it, so proper storage is the way to do it. I also run my AMS drier every night, because why not? The ones that are not in use anyway. Thats because the room I have my printer and spools in sits at 40-45% humidity, Which I am not going to change,
I have 2 KGs of rechargable silica gel in my car, a convertible which is not stored in a garage, I have to dry the gel out every 2 weeks.
My point was a care routine is vital, adopt what works best for you, but wet filament does not cause clumping, basically. If the filament was that wet, it would clog in your extruder. So dry the filament out, check the settings of the profile.
I have printed several large PETG prints over last few days, once I got my settings nailed in, PETG is perfect and my nozzle is clean, I qwrecked ,y last nozzle with bad settings.
