PFTE Tube Issue
Hello everyone. I am still a newbie to 3D printing and I have a problem. I have an A1 Mini Combo and my eSUN PLA+ has broken in the PFTE tube. When I load filament, it says to pull out so that’s what I did. The error kept popping up and I don’t know what to do. Can anyone help me?
hi,3dexplorer
when the filament breaks inside the PFTE tube, disconnect the tube from the head, push enough filament out to make sure there is no more broken filament and then pull it back into the tube and reconnect to the the head. I don’t know if you need to do the next stop, but I always do and never have a problem reloading the filament. I take the hotend out and snip of the smal bit of filament sticking out of the top of the hotend, flush with the top and put it back into the head. Then using the screen, load the filament as you normally would. let me know if this works. Also, if you search the forum, you should find many other solutions to this common problem.
Thanks for your help! I really appreciate it.
