I am using standard PLA filament sourced from a third-party manufacturer called Porima. I will list the filament’s properties below. Lately, I have been experiencing issues with my prints, such as poor adhesion to the bed and defective products. I kindly request that you provide me with the most suitable Bambu Studio settings based on the information I have provided.
Extruder Temperature = 200 - 230 degrees
Bed Temperature = 60 - 75 degrees
All filaments should work with the heroic filament profile.
If you are using this and you have adhesion problems, the issue is most likely a problem with the build plate.
Chances are you need to clean the build plate.
If the problem persists after cleaning, provide a URL for the specific PLA you purchased.
Bambu Lab doesn’t support it officially, but with the correct full information, it will work. You may need to run the calibration tests to obtain the best possible results to provide Bambu Studio.
Thank you for your comment. In a previous research I did, I saw this comment: “Since the A1 is a fast 3D printer, you can avoid these issues by reducing the print speed.” Could you share a screenshot of the settings you are using?
Reducing the speed to fix what is very likely a build plate needing a clean is not smart.
Clean the build plate first as I advised.
If you are going to ignore that advice and slow down your fast printer for no decent reason p, watch this video,
