I’m using both an X1C and A1 machine.
PLA Basic model material and PLA Support material (both Bambu) for builds.
Using standard flush volumes and have Auto calibrated materials.
0.4 Nozzle
Prime setting flush into object support option is the only option selected.
I commonly print 8 walls on models I build.
I’m seeing the PLA Support material color showing thru the walls and a wall boundary change, A step on the outer most wall.
In the attached images, I’m using Black PLA Support and Read Basic Model filament. Two of the images clearly show that where the Support interface layer is used, the model shows the Black color and an outer wall step.
I’m thinking this is a Flush volume issue however the Wall change doesn’t make sense. Suggestions?
