Hello people,
So I’m currently trying to print a multicolor miniature with a 0.2mm nozzle, using BVOH (or sometimes PVA) as solluble supports. But no matter what I try, I just can’t get PLA print onto my supports.
I tuned my support settings as much as possible, see screenshot (easier than listing it). Also, don’t mind the selected filament for support, BVOH/PVA is not supported by Bambu, so I had to copy and create a new filamentprofile for BVOH.
The BVOH prints as it should, no clogs or stringing whatsoever. Same goes for the other filament. But when the supports and interface layers are finished and the printer wants to start a new “normal” layer, it never sticks and gets blown off.
Though these first layers are miniscule details >1mm, I just can’t seem to figure out why PLA just doesn’t want to stick.
I can’t find anything about this specific issue online. Does someone here print with BVOH?
Filament used: Fiberlogy BVOH, Bambu PVA and Bambu PLA. Filament is also dried beforehand, multiple times between certain amount of prints and always stored within an AMS. Profiles are tuned to print optimally with 0.2mm with the least amount of time waste on the primingtower without any defects or gaps in the print.
Printer that I’m using is a H2C, but I have the same issues with my H2D.
I tried to play around with temps and cooling settings, but nothing helped.
I know I now only posted some support parameters, but since all the filament has no issue with printing correctly, I’m not sure what else to post that is relevant. If any other information is requested, I’ll post it right away.
