Plans for Birds Eye camera during printing?
I’m running an H2C. Now that the Birds Eye camera can be calibrated with the cutting module alone, is there any plan to let it be used during regular 3D printing, both for timelapses and for AI print monitoring?
The common problem is the live view camera’s angle. It works for a general look at the print, but it often hides what matters: how a specific region builds up layer by layer, where a defect starts, or what’s happening on the far side of the plate. That limits diagnostic timelapses, and I think it’s also why AI detection sometimes misses failures that should be obvious. If the problem is partly hidden or seen from a bad angle, the AI never gets a clear view of it. A top-down view of the whole plate would help both.
I’m not asking for a full live stream. I know bandwidth and the camera’s connection may be limiting factors, and the simplest version would cover most of what I need:
  1. Let the user choose the Birds Eye camera as the timelapse source, capturing one frame per layer like the current timelapse.
  2. A low-rate view (around 1 fps, or even a snapshot refresh) in Studio/Handy while printing.
  3. Feed those same Birds Eye frames into AI failure detection (spaghetti, clumping, etc.) alongside the existing cameras.
The first two seem like small changes, since the camera already captures stills for laser and cutting alignment. The third is more work, but per-layer or low-rate frames are probably enough for detection.
Is the Birds Eye camera used for AI detection at all today? I’ve also seen several earlier requests for printing access (H2D Nozzle and Birdseye camera feature, H2D Camera Features) but no official answer. @SupportAssistant, are any of these on the roadmap, or is there a hardware reason they can’t be done?
Thanks!
There is one thing you are overlooking, and that is that the BEV camera cannot see the rear of the build plate when the build plate is close to the tool head. The angle of the camera is not wide enough for that. Even de sides are not properly visible.
And specifically the first layers are crucial for detecting errors.
Additionally, when printing small parts, the tool head obscures parts of the print.
So imho only for option 1 and 2, it could be a useful alternative.
There have been more requests for extra use of the BEV camera, nothing so far, but who knows what will come someday.
Having just recently installed the birds eye camera in my H2C I wonder what the frame rate of the interface is. Bambu Suite makes it look very slow - snapshot on demand.
