When I launch a print to my P1S, part of the process is Cleaning the nozzle. You can sit by printer and it will cycle around on that small tab on the back of the build plate.
I use a pretty rigid garolite plate which is heavy gauge sheet metal to provide magnetic adhesion and the surface in contact with the print is a fiberglass sheet and it is pretty hard. That is Wikipedia’s description in any case.
The nozzle cleaning process has worn out a rectangular spot on the back tab.
How does the loss of that material impact the cleaning of the nozzle.
That wear spot tells me the nozzle cleaning process applies some fairly heavy pressure between nozzle tip and build plate and gives the tip a pretty stout scrubbing.
Curious as to other peoples thoughts.
