Plate confusion
If you want to get rid of the sticker of the cool plate on the steel sheet, put it in a freezer for 3 hours. Thereafter you can take it off just like that.
I ordered some Mitsubishi Pei stickers 260x260mm that I like to use after the original cool sticker felt off. For texture/smooth pei I got an energetic double sided plate from Ali. Now I just have to wait for my printer
If there is any residual adhesive on the plate, De-Solv-It Citrus Solution is magic. Saturate the surface of the adhesive, let it sit for a few hours, then scrape off the resulting material with a paper towel, finger nail, plastic putty knife, or similar. A repeat of that process might be warranted if there’s a lot of material. Then clean with mild soap and water as normally indicated for the plate.
