Hacky and hacking do not share the same meaning. Hacky is a pejorative derived from hackneyed meaning inelegant.
While the solution is “inelegant”, it does work. I don’t foresee a different solution being implemented as I feel the user base that would benefit from a this is pretty small. This being said, you might log an issue on GitHub regarding it as this is the best way to request changes that the Dev’s will see.
oh dear. semantics. ok, fine. we’ll do it your way.
why did you buy the diy machine only to then complain about diy-ing.
I didn’t buy a DIY machine. I bought a tool. I have no interest in tinkering or hacking.
And it’s frustrating to me that it has a mandatory feature (dropping objects to the build plate) that restricts my ability to use it and requires additional effort and time to bypass. I’m fine with work that has a purpose, but work to bypass an obstacle that was created arbitrarily is just a waste of time.
Say you bought a table saw and it had an automatic return spring on the blade tilt mechanism that returned it to 90 degrees after every cut, would you feel like you were a better DIYer for resetting your bevel angle over and over, or would you be frustrated that it has an unnecessary feature that makes more work for you? And after all, most users don’t make beveled cuts. Most cuts are made at 90 degrees so it’s not a big deal. But if you’re cutting your own trim it’s an unnecessary headache in your work flow.
kind of disappointing after all this time they haven’t improved software or added necessary features like thread tool, etc. Shapr3d just added that and I was surprised as advanced as it was, they did not have sooner. Kindly improve the software, I don’t like needing to pay for additional software. Bambu studio has some areas to improve also like view not rotating on the area you are focused on and how it can send you to the stratosphere so to speak.
