Poor Quality Top Layer
Bambu seems to have abandoned the X2D platform already, and they are absolutely ignoring this iuuse. It’s been months since the last firmware update.
Yeah too busy with H3/P3, maybe one day …
In the last days I was able to dial in the bambu PLA basic to very acceptable levels :D, then the filament ended, I had second roll but when I opened it it was unwound inside the roll, and the roll was not locked… So I was not able to put it back in the same roll and used different roll. But it become too tick and can not be turned inside the AMS… Then I found local supply from this filaments are sold out … Then bought different filament and now several days later can not get even close to the top finish quality. And start getting even uglier defects :smiley: . Meanwhile my mini arrived and this days will be able to compare them face2face :D.
Just an update from my side. While my previous post helped a lot clean-up the edges, nothing I did removed the ripples on bigger flat surface prints.
After talking to support they got me to replace my heatbed, and the heating assembly, and it ended up not fixing it. They analysed the printer logs and told me that the nozzle was having trouble stabilising the temperature properly. So even running it at higher temperatures (230) didn’t help with the ripples in my case.
Though might be worth printing at higher temperatures or print a temp tower before calibrating the rest, that might help.
They have currently offered a replacement, which I accepted so am waiting to return my printer, and hope that the replacement does not have this issue.
Maybe when they introduce the mixed nozzle printing for the x2d, we’ll get a bunch of other fixes as well.
Do you have some examples to share from this long line ripples?
You can see them in the first picture on this thread.
But here is the last print I did that I did after heatbed replacement. You can see the ripples and issues at the top.
It’s not as bad as I’ve had on some others, but it’s random when it decides to do it for the bigger parts of the model, or just a small part like this. It is however still there even after having re-assambled almost the whole printer to get the heatbed installed.
Very recently saw very similar “effect” on also similar size circled object. Which had no issue while I was printing with Bambu PLA basic. But it ended and needed to buy other brand which show no signs like this on smaller prints but at this size I got defects … So this is veeery strange behavior. Next days will investigate it further. But this kind of inconsistency and hit or miss behavior is driving mi nuts.
BTW on my brand new mini I tested real quick all auto + bambu PLA basic white, simple cube 40x40x1 and in the middle it is good, but ends of the seams are rough and spiky. Go figure.
Kind of start to think filament quality is all over the place.
On the other hand I had some PETG loaded to the X2D to print some spools, ran also one fast cube, and it came out brilliant and smooth. I am not sure what to say honestly.
