Possible way to fix small imperfection in large flat print?
I tried out the makerlab’s keychain from image to create a flat print. I enlarged the file to fill the plate and did not see any issues with the preview until starting to print. About 90% of the way through the job, the printer started to skip over a very tiny area of the print, leaving a small noticeable hole. Zooming way into the file, I now see the keychain tool made a small spot that it thought should be another color, but I guess it was too small for the A1 to actually print it out and instead left this tiny hole in the upper layers.
I don’t want to waste the print, as it ate a lot of time/material and is perfectly good otherwise. Are there any ways that I could fill in this tiny hole by hand and smooth it out to match the surrounding color? Possibly with the correct filament?
Use a 3D pen to fill the holes
