what are you using to get graphs/data ?
This is just a Shelly Plug (needed on my side in the first place to be able to easily turn on/off the printer) + Android app (screenshots are from the app).
I have mainly these ones :
https://www.shelly.cloud/en/products/shop/shelly-plug-s
19€ (cheaper in packs) (also available on amazon)
Gives power consumption + Alexa capability (“Alexa, turn on Bambu Lab”)
There are mainly two models, the “small” and the “big” ones, the main difference is the max allowed power (2500W vs 3500W i believe, but please check the specs) + the size of the device.
I tried the shelly plug S and works but when turning the plug off the X1C will glow the leds of the extruder ever X minute. You seen this happen?
Not at all … when i turn off the plug, the Bambu Lab is not powered anymore so nothing can be on anymore in any way.
Either you have a wrong Plug configuration (a periodic timer powering on the device at regular frequency ?) - in which case you could / should reset the device (and maybe check the logs of the device in the Shelly Cloud APP (android, …) or through the web console at http://, in which you can activate a debug log)
Either maybe you have a faulty device, in which case you should probably contact the seller or the Shelly support.
I tried factory reset and settings are ok. Not seen anything out of the ordinary from the logs. But mailed them a moment ago with footage and log. So hope they can help out.
Guess this is an old thread but this is actually something I actively monitor since I run my printers nearly continuously…I’m very familiar with mains power measurement and I’ve also just been seeing about 250-300W peak with the bed heater on. I have a Kill-A-Watt and an sort of cheap Rosewill power monitoring device. Both do power factor correction properly. I’m seeing this on both my P1P and X1C. Maybe there were batch-to-batch differences
Incorrect… higher voltage = lower amps to achieve the same wattage. VxA=W
If heater is rated for 1000 watts it would draw 8.3 amps at 120v and 4.15 at 240v, etc…
What exactly is your point? The bed heater isn’t “rated” for a particular wattage. It will draw 4X the power (wattage) on 240V than on 120V because its resistance doesn’t change.
So whats the average power usage for a 5 hour print in the UK then?
After initial heating, figure 110-130W usage, so five hours would be about 0,6kWh. How much that costs depends on what you pay for power. For me, it would be about 80 US cents.
Are you sure about your cost per KWh?? That sounds awfully high. My marginal cost is about 11 cents per KWh. Granted, I live in a state which is a huge power producer, but even so…
I rounded up. I just redid the calculation with a sharper pencil, and it looks as though I’m paying a marginal rate of about 10.4 cents per kilowatt-hour.
Not that ti really matters, but I had no idea others were paying so much.
According to energysage website, the national average is 19 cents per kilowatt-hour. California is 33 cents/kWh. Ouch.
My marginal cost is 0.23/kWh, but yes, I made a mistake. Call it 14 cents.
Here in MA I pay 0.31/kWh. It’s a bit painful.
It would be interesting to see what is the difference in consumption when printing PLA with cool plate vs PEI plate.
Not really a scientific test, but the smart socket on my X1C shows these values during printing:
- Cool Plate (35°C), Hotend at 220°C: ~70W
- Textured PEI Plate (55°C), Hotend at 220°C: ~120W
Europe, 230V Supply.
And we have a winner ! Someone who understands electrical theory and Watts law.Please let me rephrase your reply Mr. rbennett. A load that uses 1000 watts will draw twice the current at 120 volts than at 240 volts. watts law says that power = current times voltage. If you plug Mr. rbennets voltage,current and power values into the watts law formula you will see watts law proves him right.
