When you start a print and the LiDAR does its calibration at the board, then moves to the rear right corner, and then to the plate QR code, what exactly is the LiDAR looking for at the right rear corner?
Build plate alignment maybe?
Haven’t tried leaving one on, but maybe confirm you’ve removed the nozzle cleaning L in that corner
That was my guess as well.
I don’t quite understand what you’re saying. Can you clarify please.
ohhh. You’re saying maybe it’s checking if you didn’t remove the prime line after the last print? I understand now.
Maybe.
It’s not, tried to leave one on and it doesn’t notice it.
It’s to check and make sure the build plate is installed correctly. One time I had my build plate slightly raised on one corner and after this action, it alerted me to it.
