Prime tower useless
often, for figurin almost!
i found prime tower useless.
same i used 4 color, fact is when i used support,
i don’t really need raming (“éperonnage”) because is on support and
will be great bambu studio proposed it…
when or with 1% of lighting filling
Have you tried the same model with that setting on/off to compare? it might be that removes some possible stringing? (I also usually disable it too)
for stringing, i tried to calibrate mine filament before! but i used it,
prime tower, often mine first month!! now is second
I always turn off the prime tower. The printer purges filament before it changes, as it changes and then after it changes. It doesn’t need to waste any more filament!
not for all filament !! i tried some glow and different source of! if is not basic bambulab with good “amorcage”, stringing waste all
