Just curious if anyone has noticed any differences in the printed model when using the LCD touch screen to “print again” ?
I have 4 X1c printers and have observed this on each of them. If I send the print job to the printer from the slicer over the network - first time, prints perfectly - then I remove the print and the calibration lines (I do not disturb the build plate) - model comes off easily - clean the build plate and print again, this time using the LCD touch screen. I confirm the proper selected filament and build plate are shown and continue.
I have noticed that the first layer does not look the same - usually more layer lines are noticeable.
I am not sure what the difference would be - it could just be an odd thing - but it has happened.
I clean the bed start the job from the computer and the print is perfect again
When you “print again” which check boxes do you have checked? I always turn off calibration and timelapse but keep the bed leveling enabled. As a point of reference I do not see a difference in prints from sending/print again/print from SD. I often will use “print again” dozens and dozens of times.
I’ve noticed this too, and it took me a few prints using the “print again” option on the printer to realize that it was printing erroneously, it’s almost like it chooses a different plate or first layer settings. I didn’t want to bother figuring out why, I just stopped using it.
YES! - I saw this too! Another time I noticed this inconsistency was with the LCD UI - I printed with a textured PEI - verified from the slicer - printed perfectly, I go to use “print again” and this time the LCD shows a smooth PEI sheet and it does not allow you to change it. I guarantee there is some bugs here.
