the print is blocked and cannot be erased bambulab a1 mini
please help me i need resolve it i am very ![]()
have u tried switching it off and on?
I know it true, but you might as well said. “Bambu Lab tech support, Tier one” …
“Have you tried power cycling your device.” Still funny
I had that happen once. I just had to let it sit for a while and it cleared on it’s own. I think it was a server issue.
Can I assume the downloading message disappears after you turn it off and turn it back on again?
Assuming that is true, a common issue that could cause this SD card related.
If you have a spare SD card, try that, make sure to format it before use.
If not, copy the contents of the SD card you use onto a computer as a backup.
Format the card and try again.
If all works, copy the files back to the newly formatted SD card.
In my case it came back after a restart. As I said, I think it was a server side issue, and I could not do anything on the app or the printer screen because it would always say the printer was busy.
Since the OP’er has not posted again, i assume its resolved.
