Detailed description of the problem: I’m having strange issue. The quality is great on brim. But on the part, it’s horrible. I did the max vol speed calibration and quality is superb untill 30. So ive set it at 25.
Printer was left for a while and was fine before. Idled for maybe 8 months.
Printer model used: Bambu p1p
Orca settings used: default PCTG except first layer is 0.25 and max vol at 25.
Bed at 100 (had bad adherence) print temp 265
Type of filament used: PCTG (out of box, no humidity (un detectable humidity level).
There was a firmware upgrade (not sure if this could trigger this?)
Like I said: max vol printing was A1. What could do this?!
I am interesting on how your Bambu Studio slice it, as well as print profile, printer profile, filament profile.
When I load your file, it load my default profile.
Because look at your picture, it’s like your didn’t have PA enabled and too much overextrusion at the 2nd layer. I don’t know for sure just with a picture. Hence I asked for 3mf project that has complete your print profiles and all.
Try increase temperature by 5-10°C or even 20°C. My thinking is, first layer it prints slow, second layer onward it prints with double speed. The nozzle becomes cold fast with cold plastic coming through.
Btw, quick google search shows this
So, slow down the print speed would help.
Like, bring everything down under 100mm/s
Set as Stainless yes.
I’m starting to think the printer has some strange issue after firmware update (I’ve had 2 fw updates and an orca update. I didn’t try printing in between).
I’ll try to remove the PTFE tube (maybe worn) and do a direct filament print test.
Then I’ll do a complete cleanup of the extruder and see if it helps.
Then if it fails I’ll try a complete factory default of printer.
I’ll keep you posted
Ok it’s fixed.
PTFE tube helped a bit.
Combined with a clean-up of the extruder fixed it.
So i guess it was a mix of both. What i think was happening: there was a “rebound” on the filament. PTFE was a bit pinched and extruder was dirty so filament was slipping somehow …
There still some small anomalies looking closer… I’ll tweek the speed and see if it helps.
